M MSCMOE Distinguished Dec 29, 2010 1 0 18,510 Dec 30, 2010 #1 Hello, why does my computer power supply show 3 volts and 12 volts but not 5 volts?
jaguarskx Titan Apr 19, 2006 27,979 3 84,965 Dec 30, 2010 #2 don't know and you posted in the wrong section. There should be a 5 volt lead since the hard drive uses both 5v and 12v. Upvote 0 Downvote
G Guest Guest Dec 30, 2010 #3 This topic has been moved from the section Computer Peripherals to section Systems by Fihart Upvote 0 Downvote
Onus Titan Jan 27, 2006 37,037 12 89,965 Dec 30, 2010 #4 You must be referring to the -5V rail. That rail is obsolete. It was used by some AT expansion cards way back when. Very few PSUs have it any more, and those that do I would not trust to be of sufficient quality to power a modern PC. Upvote 0 Downvote
