Hello, I have problem with my ram, I have 2x2gb (OCZ 2x2GB DDR3 SDRAM PC8500 CL7.0 Gold Edition)
and whenever I use both of them I keep getting all kinds of BSOD. though if I use 1 it runs fine no matter which one I use, that suggests that they are not broken?
Strange thing is if I stick both and put bios all on default the PC wont even get to windows loading screen.
Im not good with bios setting and more technical details so any help appreciated. like what settings I should try voltages etc.
Also this problem started when I installed windows 7 x64, I had to install it using 1 ram stick otherwise it would crash the installation. only windows xp would install with 4g ram. vista and 7 x84 would always crash.
MY RIG
Sapphire PCI-e Radeon HD6870 1GB 2xDVI/HDMI/2xDP
AMD Phenom II X4 955 3.2GHz 8MB AM3 Black Box - manually overclocked x17
Antec Midi Tower Three Hundred No PSU
Antec Voeding Earthwatts 650W
Asus Crosshair III Formula AMD 790FX, SATA2 RAID
Chieftec Casefan AF-1225S 120mm, Sleeve Bearing
Fractal Design Casefan Silent Series 140mm
2xNexus Fan 120mm Silent Fan Blue LED
Noctua Processor Koeler NH-U9 AMD & Intel
Western Digital 640GB SATA300 32MB, WD6401AALS
Zalman Speed Controller ZM-MFC1 PLUS (zilver)
Samsung LED Monitor XL2370 23", HDMI (using 1080p)
MY RIG
