GTX 470 Frame rate issue
My setup is
Asus Maximus 3 formula mother board
I5 core 750 intel CPU
2x2 Gig of Ram Corsair Dominator
Ante 650 watt PSU
Asus ENGTX 470
Kingston SSD 30gb
Western Digital Raptor 300gb
Cooler master HAF 932
Running Windows 7 64bit
I also have the latest Nvidia Driver downloaded and installed but everytime I restart or shut my computer down its like it uninstalls the driver or something happens to it but all i have to do is Rerun the Install and my Video works again
My OS, Motherboard, and Video card software are all saved on my SSD the Raptor is for my Games..
Related ressources
Graphics card Master
Hmm, I never do that thing, since i never had a SSD before... :)
But still, i suspect your SSD is the root of your problem, just try that first....
strange i have the gtx 470 and win 7 -32 bit ultimate and have never expirenced such problems ever i even oc'd it try reinstalling the os or re-downloading the drivers and check ur ssd for errors that could be the problem as wa1 said but u cant just transfer it (well at least not the os)
Graphics card Expert
It does sound like your have an issue with the SSD. It would seem that drivers are being installed into memory and not being saved onto the SSD. Have you had any luck since wa1 first suggested installing everything on the HDD?
I personally own one of these Kingston SSD now drives and they aren't meant for gaming but are mainly for laptops or as paging drives. Their random 4K read and write compared to other SSD drives for their cost. Move every thing as they have suggested over to the hard drive and once done. Move the pagefile over to the SSD. it will help in games like GTA IV or Gothic4 while other things like making large videos it will help but beyond that you won't see a big boost.
My thought is you should properly do a clean uninstall of all your Nvidia-related software and drivers, restart, then install the latest Nvidia drivers. This will hopefully rule out a driver conflict.
I did this on just the Raptor Drive and It acted the same run the Game perfect until I restarted my computer Then the Frame rates started dropping again. This is Crazy I have never had this much of a Problem with a Video card...
probably sum goddamn virus check Ur av and reset registry settings to default and format everything top to bottom change ur mobo(not necessary ) then try using the 32-bit version of win 7 and b4 u do any of this check ur ssd and raptor with the check disc utility and also defrag them
Have exact same problem... totally different rig... would love to find the solution too... its not your hardware...its gottta be a win 7 thing... have used 3 differing nvidia driver versions everytime i reboot frame rate drops in WOW only, everything else is unaffected... SAD FACE.
Ask the community
