Hello, I am fairly new to the PC building process and I am looking to put together a machine that does it all as far as media is concerned (record HD Tv - cable, play stored movies, play Blu-rays and HD-DVDs, and of course Netflix). I won't really be using this for gaming.
I am looking to build a system that can handle the Ceton InfiniTV 4 card (ordered it, now playing the waiting game). I have listed below a build that I would like to do, but as I said earlier I am fairly new to this so I am not sure if all the components match up correctly, or will fit in the case:
MoBo:
ASUS P7H55-M PRO LGA 1156 Intel H55 HDMI Micro ATX Intel
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131623
Processor:
Intel Core i3-540 Clarkdale 3.06GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115221
PSU:
Antec EarthWatts Green EA-380D Green 380W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
RAM:
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
HardDrive:
Western Digital Caviar Green WD20EARS 2TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136514&cm_re=2_tb_harddrive-_-22-136-514-_-Product
Blu-Ray/HD-DVD:
LG GGC-H20L BLURAY SUPERMULTI HD DVD
http://www.esaitech.com/commerce/ccp54421-lg--ggc-h20l-bluray-supermulti-hd-dvd-dvd-rw-sata-ggc-h20l-1114367.htm?gclid=CNSFwYvvlKYCFce7KgodGT__pA
Case:
Steel HTPC 5000B Micro ATX Media Center
http://www.newegg.com/Product/Product.aspx?Item=N82E16811204035
I will be using Windows 7 as my OS. The Blu-ray HD-DVD combo drive isn't necessary but I have an HD-dvd player for my xbox which will be in the other room so I can use it as an extender for the Ceton card.
I was hoping for input first and foremost to see if this build is possible, if it isn't then are there recommendations? I don't want to get too pricey, ideally I'd like to keep the build on/under the $1,000 mark with the cable card reader.
Thanks much!
MoBo:
Processor:
PSU:
RAM:
HardDrive:
Blu-Ray/HD-DVD:
Case:
Thanks much!
