Asus p7p55 Lx
Intel i5 750
4gb 1600mhz gskill ram
400w ocz PSU
hd 4870 512 gfx
Samsung sata 2 500gb hdd
Maxtor 300gb ide hdd
June last year I built the above system and it has run smoothly for the whole of that period except for the last couple of months. It all started out with the occasional blue screen when booting the computer up. Reset or two later it would be fine. This may have just been a bug that I managed to take care of though, so may be unrelated.
Anyway so a few weeks ago I get a stupid ass “usb current overflow detected computer is shutting down” error. This happened everytime the computer booted up. Well after updating the bios and resetting them the error disappeared. However now instead of this error when the computer has been off for anything from 2 hours plus the computer will start to boot and then black screen.
When it does this it cannot be reset via the button on the front but the switch must be flicked on the back and when powered back on it sounds as if the hdd is booting up really slowly before displaying anything on screen which is not what it usually does basically, so I thought this could be the problem.
I however unplugged the hdd today and booted it up and the system crashed on checking nvram. After the computer has rebooted about 3 times it will not suffer any more problems until it is powered down for a number of hours. Most of the computer is also brand new and as you can imagine its driving me nuts as I don’t want to send the system back and be without a computer for weeks. I would rather smash the damn thing up at this point and order a new one no kidding. This is how much it’s annoying me.
Sometimes the computer will boot, be on for 5 minutes and then black screen I have no idea what it is as it’s not the hdd. So I thought dodgy ram possibly however I haven’t bothered doing a memcheck on it as my old system had a bad stick of ram was crc erroring all over the shop yet passed a 24 hour test on that piece of *** program that is memcheck.
What could this be or do you think I’d be better off smashing the piece of crap up?
Some other things to note i doubt is the PSU as when the system is powered on its fine for hours without a single crash for example i was playing Crysis 2 on full spec last night for about 6 hours no crashing nothing.
Id would really appreciate anyones insight because to be honest i haven't got a clue whats causing this problem.
Intel i5 750
400w ocz PSU
hd 4870 512 gfx
