Hi all, after buying and putting all my pieces together I've run into a problem.
Powering up the pc starts all fans and LED's in the case for around 2 seconds and then turns itself off, then without any human interferance it repeats this task.
I know its very difficult for you all to identify problems when there isnt anythink to look at but if anyone can suggest ANYTHING then it would be a great help.
If it helps heres my specs -
Gigabyte GA-h55m-ud2h
i5 760
GTX 460 Hawk 'Talon Attack'
Corsair Dominator DDR3 2x2GB
Corsair TX650W
LG DVDRW
Samsung F3 1TB
i5 760
Corsair TX650W
LG DVDRW
Samsung F3 1TB
