After much research I have finally put together my new computer build, but wanted to check with the vets here to see if I have missed anything. Will this all work together and am I over/under doing anything? Any forseen issues or suggestions will be much appreciated. This is my first time building a pc.
Thanks
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103894&Tpk=N82E16819103894
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
CASE: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Thermal compound: http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Heatsink/Fan: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=coolermaster_hyper_212%2b_air_cooler-_-35-103-065-_-Product
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136786
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Also, Any suggestions on a 1GB video card?
Thanks for the help
Thanks
Thanks for the help
