Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Keyboard problem after laptop repair
Forum Laptops & Notebooks : General Laptops & Notebooks - Keyboard problem after laptop repair
Archived from groups: comp.sys.laptops (More info?)
I have never worked on a laptop before, but a friend brought me this
Toshiba Satellite S1670 CDS running Windows 98SE with a dead hard drive
and asked me to do anything I wanted to try and fix it.
The hard drive replacement and W98SE install went smoothly, but I found
that some of the keys on the lower right of the key board no longer
responded.....Shift/UP Arrow/L&R Arrow, and maybe some others are no
longer working.
When I removed the keyboard to acess the hard drive I unplugged the
ribbon connecters to the mainboard. I have since been told that this
was a mistake because the ribbons are very difficult to replace
correctly.
Can anyone confirm that this is the probable cause of the unresponsive
keys and advise how I might get them working again?
I really would like to give my friend back a perfect computer which it
would be otherwise
Many Thanks
Sponsored Links
The ribbon cable is not normally the reason keys stop working. The membrane
under the keys go bad. You normally cant fix the keys, just replace the KB.
As to the ribbon connectors, do you have the bare end of the ribbon showing with
no connector and a slot on the MB? If so, look at the connector on the MB, it
should have a small lip around it. - Gently - pull up a small amount along the
edges(about 1/16" ), opening the friction clamp. Slip the end of the ribbon
cable back into the connector and press the slide back down securing the ribbon.
TJ
> longer working.
> correctly.
> would be otherwise
> Many Thanks
I am BillGatus of Borg. Resistance is futile. You will be assim
[General Protection Fault]
Reply to Anonymous
- 0 +
Thanks TJ....Your suggestion is appreciated.
I had been very careful removing and replacing the ribbon connectors
just as you described.
I had assumed that the keys were all working when I got the laptop
originally, but perhaps they weren't. It had been stored for some time
in a garage in less than ideal conditions which would explain any
deterioration.
No matter, the laptop is reasonably useable as it is. I doubt if the
owner would want to pay for a new keyboard...they will be letting
their 7 year old daughter use it.
"Capt. 'Wild' Bill Kelso, USAAC" <Dec7.1941@cableaz.com> wrote in message news:<42192485.9A784109@cableaz.com>...
> TJ
Reply to tui
> deterioration.
I have a large stack of Thinkpad KB's that have several dead keys or dead
mouses.. mice... meese? I've tried to repair but its just not worth it, even
if you can find a membrane to replace it with.
Keyboards are actually pretty cheap... It wouldnt be more than $35-45 on eBay
and that would be with shipping. Swap just the KB, dont need the whole
assembly(bezel, speakers, etc).
Good luck with it..
TJ
> > TJ
Reply to Anonymous
- 0 +
Ok TJ, thank you....I will pass on the information to my friend
"Capt. 'Wild' Bill Kelso, USAAC" <Dec7.1941@cableaz.com> wrote in message news:<42197080.4915B88C@cableaz.com>...
> > deterioration.
> Good luck with it..
> TJ
Reply to tui
There are 743 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
