How do I connect the front part of the case (USB) to the motherboard?
Last response: in Components
Power supply Expert
Motherboard Expert
Since the connections from the front panel:
- audio
- USB
- and Power, Reset, HD LED, and PWR LED
All connect to the motherboard, you need to look in the motherboard manual to see where to connect those cables.
POST exact motherboard manufacturer and model if you need more help
Power supply Expert
Motherboard Expert
I assume you have the manual if not :
Pg 2-2 shows location of all MB headers. Also labeled on MB.
Pg 2-14 show how to hook up : JFP1
Power LED (NOTE the + is important if it's connected wrong, LED won't light )
Power Switch
Reset Switch
HDD LED (NOTE the + is important if it's connected wrong, LED won't light )
NOTE: cable from front panel is labeled "USB" if you get it on the wrong MB header system will BURN !!!!!
Pg 2-15 : JUSB1 (how to connect USB to front panel. NOTE: 2 ports on this ONE cable..)
Pg 2-16 : J1394_1 IF your case has a front panel FireWire
Pg 2-18 : JAUD1 connect your front panel audio cable.
Power supply Expert
Motherboard Expert
The best information will be in your motherboard manual. If you can, download it from the manufacturers website, it will be much easier to read.
Ask the community
