First gaming build please help.
Last response: in Systems
Approximate Purchase Date: 1/31/11
Budget Range: 600-700 (including OS)
System Usage: Gaming (SC2, Fallout NV, Guild Wars 2, and Diablo 3)
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: None
Country of Origin: USA
Parts Preferences: AMD CPU
Overclocking: Maybe
SLI for now Maybe Crossfire in the future
Additional Comments: The parts have been tentatively selected. Please let me know if you see any issues or anywhere I can save a few dollars.
Case:
NZXT GAMMA Classic Series GAMA-001BK Black Steel ATX Mid Tower Computer Case
HDD:
SAMSUNG Spinpoint F4 HD322GJ/U 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
*MOBO* Update (thanks rolli59)
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
Network: Wireless is required.
Rosewill RNX-N180PCe PCI Express Revision 1.1 Wireless Adapter
GPU:
HIS H577FK1GD Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
CD:
SONY Black SATA DVD-ROM Drive Model DDU1681S-0B – OEM
*PSU* Update (thanks rolli59)
Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified ...
RAM:
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT
CPU:
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
OS:
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders – OEM
TOTAL COST $705.90 before rebate $645.90 after rebate
Any thoughts?
My concerns:
1. Will there be any problems with the network card
2. Will everything fit in that case including future crossfire?
3. Is the PSU of sufficient quality?
Thank you for your help,
Joe
More about : gaming build
I personally have had terrible experiences connecting wirelessly with the pci cards, instead I use a usb yagi antennae found one on ebay and they work much better for me. The wireless will work fine for if going through at max two walls but three or more walls require a decent yagi or cantina antennae
flatbaler87 said:
Alright thanks for the input. are there any other options for crossfire capable mother boards or this that the cheapest one?
This was the cheapest I could find for AM3 without going open box.
Ask the community
