Problems with extended display!
Related ressources
- Problems using HDTV as an extended display - Forum
- Extended display issue - Forum
- Extended display problem - Forum
- 4870 Extended display Windows 7 - Forum
Related ressources:
- ForumSource.
- ForumCan I get 2 taskbars on dual monitor extended display ?
- ForumProblem with green tinted display on extended monitors
- ForumRadeon 5800-series card/green tint on extended display
- ForumExtended Desktop Display through a single DVI output? [Dual Monitors]
- ForumHow can I view an extended display if it's in another room?
- ForumIssue getting digital display on extended monitor
- ForumRadeon HD 5850 and Extended Display
- Forum[Solved] HD 6950 micro-stuttering + tearing fix for extended displays
- ForumExternal USB hard drive extended partitions issue
- ForumNeed opinion for new GPU -- Eyefinity plus one extended
- ForumUpgrade to GTX 680 Classified from this?
- ForumWhats the deal with graphics cards?
- Forum[Solved] Display 220$
- ForumComputer restarts with resolution Change/Native resolution not availab
- More resources
Anyways, the problem was due to multiple problems and having faulty hardware. The IBM screen was actually broken, and even tho the BenQ screen showed the exact same symptoms, the problem was not related ( just weird coincidence ).
