hi
I built this computer couple months ago and since then the computer has been running kind of sluggish. I think it might be my memory running slow maybe due to incompatibility with the motherboard? I'm not really sure but I don't think the memory is running at its potential and causing the computer to slow down. I have tried re-installing windows twice but it didnt help either.
Boot-up time is also slow compared to my friend's computer which was just a dual-core, which i built a month using a different model gigabyte motherboard. The boot-screen stays on screen forever and then sometimes gets frozen if i restart the computer and have to turn it off and turn it back on.
Motherboard:
GIGABYTE GA-790XTA-UD4
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128416
Memory:
G.SKILL Ripjaws Series 4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=gskill_ripjaw_4gb-_-20-231-303-_-Product
When I run CPU-Z It shows
http://i55.tinypic.com/wlf3nl.jpg
Motherboard:
Memory:
