GTX 460 SLI problems/questions
- Nvidia
Graphics
calmstateofmind
November 4, 2010 3:40:41 AM
So a few months ago I built a new gaming system, here's the specs:
-EVGA GeForce GTX 460 1GB (Fermi) x2 SLI
-Intel Core i5-750 OCed @ 3.8GHz
-Corsair Nova 32GB SSD
-Samsung 2TB HDD
-WD 750GB HDD
-WD 1TB external HDD
-EVGA P55 SLI motherboard
-8GB CORSAIR DOMINATOR DDR3 RAM @ 1333MHz
-Rosewill Xtreme Series 850W PSU
I just recently bought the 2nd 460 and have ran benchmarks with both cards enabled and with only one. Between the two I'm only seeing a small difference in frame rate. I'm wondering if there was a way for me to verify that both cards are in fact being used? I have EVGA Precision and on the charts it shows activity and I see both cards listed in Nvidia Control Panel, but I still don't see it reflected in the frame rate. I'm running the Lost Planet 2 benchmark.
Is there something I'm missing?
P.S. My first card is in a x16 2.0 and the other is in a x4. Would there be a noticeable difference in perform between the two because of that? Does that effect the SLI in any way?
Thanks in advance.
-Samsung 2TB HDD
-WD 750GB HDD
Thanks in advance.
More about : gtx 460 sli problems questions
skolpo
November 4, 2010 3:50:09 AM
calmstateofmind
November 4, 2010 4:00:46 AM
skolpo said:
Some basic questions: Is SLI enabled in nVidia Control Panel? Are you using an SLI bridge? Are both cards powered correctly with two 6-pin PCIe power connectors for each card? Download GPU-Z to check if your SLI is enabled.Yes, I'm using an SLI bridge. Yes, the power connectors are 100% secure and have 2 6-pins in them. I have looked at GPU-Z and it shows both cards, but does that mean that the SLI is in fact working or just that both cards are being recognized? Where in the Nvidia Control Panel do I have the choice to enable SLI? Is that SOP for SLI?
m
l
- SLI of EVGA GTX460 1024 and an EVGA GTX460 768 cards worthwhile? - Forum
- Upgrading GTX 460 SLi to R290X or GTX 780 Ti and/or other components - Forum
- gtx 460 for sli but differnt amounts of vram (768 and 1024) - Forum
- New GTX 680 problems/questions - Forum
- GTX 460 SLI Setup - Forum
skolpo
November 4, 2010 4:21:29 AM
calmstateofmind
November 4, 2010 5:32:05 AM
skolpo said:
In nvidia control panel, under 3D Settings, there should be a menu that says "Set SLI and PhysX configuration." Make sure you have the latest drivers. In GPU-Z, at the very bottom, right above "Computing", it says NVIDIA SLI. If your SLI is working, it will say "Enabled (2 GPUs)."I opened GPU-Z and under Nvidia SLI it says disabled!!!
I have the bridge connected, the card is getting recognized by my device manager, GPU-Z, EVGA Precision and HWMonitor so I know everything is connected correctly. When I opened Nvidia Control Panel I didn't see anywhere of it mentioning SLI, only "CUDA GPUs" and then it check marks both cards automatically. Please help!
m
l
skolpo
November 4, 2010 5:52:53 AM
calmstateofmind
November 4, 2010 6:07:56 AM
calmstateofmind
November 4, 2010 6:21:01 AM
m
l
calmstateofmind
November 4, 2010 6:37:00 AM
calmstateofmind
November 4, 2010 6:48:40 AM
I just did a clean install of the drivers, along with the control panel and everything else and then reset my pc. I turned it back on, opened the control panel and selected sli again. Hit apply. It sat there for a few seconds saying it was loading and then it went blank, my mouse pops back up (but the rest of the screen is blank) and it stays frozen. The entire computer.
m
l
skolpo
November 4, 2010 6:58:05 AM
calmstateofmind
November 4, 2010 7:34:03 AM
skolpo
November 4, 2010 7:41:14 AM
ebay has plenty and they're relatively cheap. But let's not conclude that it's the bridge's fault just yet. Have you tried running benchmarks with the new card only? This will test whether if the new card might be faulty or not. You can even try to swap the cards and see if SLI works that way instead. Also, try what mousemonkey say and run the computer with only one stick of RAM, or at least try reseating them to check if that fixes the problem. If that doesn't change anything, then you should start trying older drivers.
m
l
calmstateofmind
November 4, 2010 7:47:47 AM
calmstateofmind
November 4, 2010 7:53:00 AM
skolpo said:
ebay has plenty and they're relatively cheap. But let's not conclude that it's the bridge's fault just yet. Have you tried running benchmarks with the new card only? This will test whether if the new card might be faulty or not. You can even try to swap the cards and see if SLI works that way instead. Also, try what mousemonkey say and run the computer with only one stick of RAM, or at least try reseating them to check if that fixes the problem. If that doesn't change anything, then you should start trying older drivers.No I haven't but plan on doing so in the morning. I'll also try to single stick of RAM. I think the problem is just with drivers. If it were with the card itself, I don't think it would be as influential with the rest of the system as it is. I'm going to try older drivers real quick to see if that's the issue. If not, more to come in the morning.
m
l
calmstateofmind
November 4, 2010 7:53:55 AM
calmstateofmind
November 4, 2010 2:04:12 PM
Mousemonkey said:
I just found this picture showing the bridge and does look like a ribbon rather than a hard PCB.http://media.bestofmicro.com/9/A/228430/original/evga_p55-sli_kit.jpg
Is this the same as yours?
Because it is...lol. It has EVGA and Nvidia printed on the cable. I don't think that the problem is the bridge, I think it's the drivers. The reason why I think this is because I tried an older driver and then tried to run GPU-Z and the computer froze when starting that up so that would suggest a driver issue. I'm also getting these crash codes and looked them up and other people have the same issue, but I don't know which drivers that I should use...
m
l
Do you have the latest bios installed for your m/b ?
If you o/c , I would set everything back to stock.
Maybe uninstall your driver, use driver sweeper to start fresh.
When I unable or enable sli , there is a uncomfortable blink , dark state, sometimes I even loose the monitors resolution as the driver re-loads with sli enabled.
Once out of many times it did crash, I had to restart the pc, but then all was working.
Have you switched cards and verified both video cards work solo ?
Since when that second one is asked to function now, is when your crashing ?
m
l
calmstateofmind
November 4, 2010 4:39:51 PM
notty22 said:
Do you have the latest bios installed for your m/b ?If you o/c , I would set everything back to stock.
I tried just running the 2nd card alone and there were no issues. I'm going try reinstalling W7 and install drivers from there to see if that does the job. And yes, I have run both cards separately, and in both of the PCI slots.
m
l
- SolvedGTX 460 in SLI vs GTX 770 2GB Forum
- SolvedGTX 460 SLI vs. GTX 760? Forum
- SolvedUpgrading Graphics from a pair of SLI GTX 460s. Suggestions? Forum
- SolvedGTX 460 768 in SLI or GTX 660 Forum
- SolvedWould Gtx 460 1gb SLI be able to handle Nvidia 3d vision? Forum
- SolvedMSI NVIDIA GeForce GTX 460 HAWK (TALON ATTACK) 1 GB (SLI) in 2013/2014? Forum
- SolvedGtx 460 sli 768mb and 1gb Forum
- SolvedGTX 460 SLI vs. GTX 650ti Forum
- Solvedgtx 460se Sli vs gtx 770 4gb Forum
- SolvedPhenom II X4 965 BE with GTX580 + GTX460 for Physx or GTX580 SLI Forum
- GTX 460 SSC SLI upgrade to GTX 670 Forum
- SolvedGtx 460 sli and 500 watt Psu? Forum
- Solvedfx-6100 bottleneck gtx460 sli? Forum
- Solvedhelp with fx-6100 for gtx460sli Forum
- SolvedSLI Not working on GTX 460 (Confused) Forum
- More resources
