Need advice on components for new gaming build
Hello,i am going to build my first gaming pc , i have decided on an athlon ii x4 640 , a palit gtx 460 sonic gpu , 4gb ddr3 ram , 500 gb hard drive 7200rpm SATA for around 500 euro for all the components , with my components im wondering what type of performance i will get like will i get good fps and does anybody have any suggestions for making the system better ?
will it be able to play games such as total wars, mass effect 2 and crysis on high or ultra settings
1 answer Last reply
More about need advice components gaming build
  1. Thats not going to run Crysis on high settings with 500 euro. Increase your budget you can drop the 460 and move up to a GTX 570 to get close. Also your CPU could go to a Core i3-540 for that price range and overclock it. $15 more for i3 and save some extra money for your GPU if you want to game that high. What resolution are you at? What motherboard are you using?AMD or Intel?
Build Gaming Components Systems
