HTPC build help
Last response: in Systems
January 4, 2011 3:18:18 AM
Howdy there,
Just got ourselves a very nice 55 inch LCD TV and debating whether or not to cancel our cable tv which cost $69/month and replace those cost with an HTPC.
Right now I'm sorta debating whether or not to build one myself or maybe just buy the Mac Mini (lacking bluray drive is a bummer). I was also wondering whether there are any good ready-built HTPC to buy out there (ASRock, etc)
Approximate Purchase Date: January-April
Budget Range: somewhere in between $500-$1000
System Usage from Most to Least Important: output movies to HDTV, converting DVD/Bluray to HD Video, web surfing plus other normal HTPC usage
Parts Not Required: monitor, speakers
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: none
Overclocking: No
SLI or Crossfire: Maybe
Monitor Resolution: my 55i-inch Samsung LCD
Additional Comments: needs to be quiet!
More about : htpc build
January 4, 2011 3:42:39 AM
Do you intend to watch OTA High Definition(CBS, ABC, NBC, etc)
m
l
January 4, 2011 3:47:31 AM
Definitely will get a good indoor antenna to watch OTA HD if i cancel my cable (which seems more likely the more i think about it).
m
l
January 5, 2011 2:23:43 AM
*bump*
No one else to help me out?
m
l
January 5, 2011 5:04:48 AM
Hm.... If you're not going to do any gaming, you probably don't even need an independent graphics card let alone SLI/crossfire
m
l
