USB speed
Hi
there is a USB device that state a speed of:
Transfer rates of 480 Mbps (HiSpeed) / 12Mbps (FullSpeed)
what soes it mean? why there is a "HiSpeed" & a "FullSpeed"?
& what will be the speed for transfering 1Gbyte?
thanks
1 answer Last reply
More about speed
  1. HiSpeed is USB 2.0 and Fullspeed is USB 1.0.
    What speed you get depends on what connectors the USB device and your computer has. This is because USB 2.0 is backwards compatible with USB 1.0 and will list both speeds as they are standards it will work at.
    1GB will take 17s at 480Mbps and 85s at 12Mbps.
USB Devices Components
