Okay I may be posting in the wrong subject but this is sort of a split issue. I'm currently running dual monitors using my monitor and also running my TV via an HDMI cable from my GPU. The problem I'm having isn't with dual monitors but with the sound between them.
What would be ideal is that when I'm running a game or whatever on my monitor and then maybe streaming a video on my second monitor (the TV), I'd like the game's sound to come from my computer speakers and the video sound to come from my TV. To this point I haven't found a way to make that happen. All that I know to do is go to control panel and set the default sound device to either my TV or my speakers. There's no option to split the sound between the two. So right now if I'm doing separate tasks on two different monitors, all of the sound is either from my speakers or from the TV. I know most dual monitors set ups are run with two actual monitors side by side so this isn't an issue, because of this I can't imagine this is a common issue.
So my goal is to have the sound from any task running on my monitor to come out of my speakers. At the same time, any task that is running off of my TV should have its sound running through my TV. Any ideas?
