New AMD Fusion System VS Phenom II x4 System
Last response: in Systems
Related ressources
I dont have unlimited money to spend on the pc, so 6850 or 5830 are the only two im really considering.
What makes the 955 stand out more than the 945, other than easy overclocking?
the 5870 is only 200 after rebate woth the extra few bucks and just a suggestion
if you look at the link i gave to tom's faster clock speeds and easy overclocking
just raise the multiplyer only thing getting oc'ed is the cpu witch is better for
gaming most motherboards will come with there own overclocking software you can use from windows so you can o.c only when needed again just a suggestion
these will be better values especially if your going to keep this settup awhile no such thing as good enough
again better values in the long run butt your call just my 2 cents
Ask the community
