Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > 5970 running slower than my 5870!... Help!
Forum Graphics & Displays : AMD Radeon 5970 running slower than my 5870!... Help!
Hey guys,
I, having problems with. My 5970 I've got an XFX 5970 Black Edition 2GB, it's in my computer on a PCIe 2.0 16x Slot connected to a good 1000W PSU,
My CPUs are 2.66 GHz Quads. Two of them 8 cores total,
Ive over clocked to 3.2 GHZ by upping the FSB to 1600Mhz
I've got 12GB DDR2 FB-DIMM RAM @ 800mhz
And my boot disk is a Crucial C300 SSD.
I've got my 5970 at stock speeds, but vie also over clocked it by increasing voltage and upping bits to the speed of a 5870 850/1200...
Now here's my problem: my FPS In Batman arkham asylum is 58FPS average, if I overclock it's 58, if I put it in a 8x slot it's 58, if I put it in a 4x slot it's 58, if I connect it to an external 450w PSU it's.... 58
Ok so fine your thinking that's the speed my 5970 can get out of this game is 58FPS so now here's the bizarre bits, my 5870 which I also own gets thee exact same results.
So maybe your thinking it's the game. So I've tried Crysis, Crysis warhead (both of which are the same regardless.) my copy of mafia 2 I get 65 fps with my 5870 and only 40 fps with my 5970!
Temperatures, it's not temperatures, they are within acceptable range and with my fans running full below standard ranges.
I've disconnected everything else from my computer, hard drives, optical drives USB stuff etc etc. And here I am.
So leaving MSI Afternurner running shows that normally my GPU 1 is running at about 80% and number two at 30%! when clocked at normalnspeed and worse when over clocked, no idea why.
Sony Bravia TV 1080p 60 Hz...
Help
Reply to neckarb
Hello and welcome to the forums
First of all,revert your OCs to stock speeds and see if it helps. and make sure you have the latest VGA drivers installed.Also is CrossFire enabled? open CCC>Graphics>3D>AI and make sure "Disable catalyst AI" is unchecked.
Reply to Maziar
- 0 +
Thanks for the reply, unfortunately I've tried all of the above.
Reply to neckarb
- 0 +
I too have a 5970 black edition. I also get 58fps in warhead aT 1680X1050 4aa and everything on enthusiast. What res are you playing at. Are you also saying your 5870 will run warhead at 58fps also? Running Mafia, not all games are optimised for crossfire and can actually degrade performance in some games which may explain your drop in performance in Mafia.
I used to run a GTX295 and since the Nvidia drivers tend to be better I was able to run off 1 gpu rather than both and sometimes I had an increase in performace. I owuld have thought the 5970 would kill the 5870 in Crysis Warhead though.
------------------------------ Core i7 OC 3.6Ghz
ATI XFX HD5970 Black Edition
Corsair 1000W
12Gb DDR3 1800
Reply to kkkk1
from what i see it's not a hardware problem.why don't you try posting this on ati forum?
Reply to mohsentux
There are 2001 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Graphics Card Help for a Casual
By geofelt, 1 hour ago:
As a standard, a pci-e x16 graphics card slot can deliver up to 75w to a graphics card...
Best offers
Top experts
