Will this build work
will this build work sorry links may not work didnt work for my last post
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817190025
gpu = x2 EVGA GeForce GTX 580 = $ 1030.18
N82E16814130587&cm_re=GeForce_GTX_580-_-14-130-587-_-Product
motherboard= ASUS Crosshair IV Extreme AM3 = $309.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131667
cpu AMD Phenom II X6 1090T Black Edition = $239.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103849
water cooling Thermaltake CL-W0121 2U Drive Bay Water Cooling System = 149.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835106108
hdd x2 Seagate Barracuda 1TB 7200 RPM = $69.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148433
cd/dvd burner = SAMSUNG Black 22X = 17.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827151188
memery = x4 CORSAIR XMS 4GB 240-Pin DDR3 = 359.96
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145327&cm_re=CORSAIR_XMS_4GB_240-Pin_DDR3-_-20-145-327-_-Product
moniter =x3 ASUS Black 22" 2ms(GTG) Widescreen LCD Monitor = 479.97
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824236050
links are here links work when submitting this to the form dont know y thay dont work in form any hel would help
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811144241&Tpk=Apevia%20X-Cruiser%202%20Case%20-%20Blue
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130587&cm_re=GeForce_GTX_580-_-14-130-587-_-Product
1 answer Last reply
More about will build work
  1. omg the links dont work hope the person who reads and helps can serch them all products are on www.newegg.ca
Build Systems
