Will this motherboard be compatible with my system? If not can anyone recommend something more suitable? Thanks.
answer
Last reply
More aboutchoosing replacement dead motherboard
o1die
The asus will work fine, but you'll need a new windows coa if you're still using the original windows installation that came with your system. I would also change out the power supply at the same time. That hp board isn't that old, so the ps may have taken out the board. I recommend either antec or corsair 500 watt units.
