Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > [Solved] New build confusion. Looking for help.
Forum Systems : Homebuilt [Solved] New build confusion. Looking for help.
Best answer from MadAdmiral.
Hello everyone. I am looking to build my father a gaming machine. Mainly for titles such as WOW, SWKOTOR and Black Ops. He is retiring from the police department after 34 years. He has always wanted to build a system so I am going to buy all the parts to surprise him and then we can assemble it together. I figure it's the least I can do for the sacrifices he has made for me over the years and to show how blessed I am to have him retire in perfect health.
I was not going to post because I was pretty up on this stuff a few years ago before making a career change into telecom. After spending weeks reading about all of the new equipment I am honestly baffled and my brain hurts. So I am here asking for help in piecing this together.
To start I am mainly looking for help with PSU, Video card, CPU and MOBO. I am on a bit of a budget that can be adjusted a little but let's start with $700 give or take. I am looking for something that will give him a great system for the above titles but still has many upgrade options for him in the future.
1) CPU - I am leaning towards AMD over Intel. Not because I prefer one or the other but I may be able to get more bang for my buck.
2) PSU - I have read that Corsair and Seasonic are my best bets here. I am very confused on if a 750W will be enough and I am confused on ball bearing vs. thermal control
3) Mobo - In comparing these I am totally baffled now. I have been looking at these two but wonder if I am missing many other good options. GA-870A-UD3 / M4A89TD PRO/USB3
4) Video Card - Really debating the HD6850. Great reviews but if is beefy enough for a few years?
Any help you all can provide would be of great value. I have been reading these forums for a long time and there are many knowledgable people in this community.
Reply to MileHigh Hitman
Best answer
Here's a full build:
CPU: X4 955 ($145)
Mobo: ASRock 870 Extreme3 (Crossfire) ($90ish) or ASRock 770 Extreme3 (no Crossfire) ($75ish)
RAM: Any 2x2 GB kit of DDR3 1600 mhz CAS Latency 9 ($50ish) (or CL 7, probably $70, if you're overclocking)
HDD: Samsung Spinpiont F3 1 TB ($70)
GPU: HD 6850. Turn it into a 6870 with a BIOS flash (google the instructions). This will be fine for the games he's playing, and if it's not, you could opt to Crossfire later.
PSU: If you're not Crossfiring, a 550W from Antec, Corsair, SeaSonic, or Silverstone (the highest quality brands) (likely around $60). If you want to Crossfire, pick up a 750W from the same companies or XFX (around $100).
Case: Rosewill Destroyer, Rosewill Challenger, HAF 912, Antec 300 Illusion, Coolermaster 690, Antec 900 (or 902), HAF 922 or anything from Lian Li. Or really any ATX mid- or full- tower with more than a couple fans.
------------------------------ How to Ask for New Build Advice
Troubleshooting
Reply to MadAdmiral
CPU: X4 955 ($145)
Thank you very much for the reply. I will look into these suggestions now. I would think giving him more options (crossfire) for the future would be best.
Is there a specific brand for the 6850 I should look into? All seem to be about $179
The GV-R685D5-1GD has two fans while many of the others have one.
Not really. Pretty much all of the brands are the same, so there isn't a huge difference. I'd either get one of the cheaper brands or one with the best warranty.
Troubleshooting
Reply to MadAdmiral
Thanks again. I really appreciate it.
There are 2001 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 27 minutes ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
