Keyboard Doesn't Work On New System !
hooman79108
27
Hi all
I've installed new system right now:
M.B : Asus P8P67LE
CPU: Core i5 2400
RAM: Corsair 2*2G
Power: Thermaltake 600W
VGA: Sapphire 6790
HDD : WD (I've bought it 4 years ago)
I think I've installed evrything correctly but at first the HDD was not detected and keyboard didn't recognized, when I changed the HDD chassis from Sata 3G to Sata 6G port the HDD was detected but keyborad doesn't work. there is a message at the start up of system " Press DEL to enter EFI BIOS setting" .
G
Guest
Guest
check your mobo manual, i recently had HDD problems, you may raid selected or something like that, took me a few hours to find the right bios settings on mine, they were wrong from the start. try a different keyboard, or plug it into a few other usb ports
