hey guys i just got my new hardware and i notice that the shape for the eatx 12v mobo connection is different then the psu connector... is it still safe to use or what should i do
i have asus m4a89gtd pro mobo and antec EA-500d green psu
am i using the wrong connectors? the antec website says "8 (4+4)-pin ATX12V/EPS12V connector for CPU"
do i need to use both 4pin connectors? the one 4pin fits perfect. but, the second connector has a different shape layout.. on the second connector all 4pins have the half rounded square shape. instead of the
square/half rounded square
half rounded square/square
i did notice there was a black plug in the eatx 12v on the mobo blocking 4pins should i be only using the one 4 pin connector?
thanks for your help!
RCB
RCB
