Help new build
Hello,I'm planning on building a gaming computer and I was wondering if this build would work as well as if I forgot anything important.
Fractal Design Define R3 Black ATX Mid Tower Silent Computer Case 2X5.25 8X3.5INT No PS Front USB
Western Digital WD20EARS Caviar Green 2TB SATA2 3GBPS 64MB Cache 3.5IN Hard Drive OEM
Creative Sound Blaster Audigy SE PCI 7.1 Surround Sound Card (OEM)
Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan
OCZ Gold OCZ3G1333LV12G 12GB DDR3 3X4GB DDR3-1333 CL 9-9-9-20 1.65V Triple Channel Memory Kit
Intel Core i7 950 Quad Core Processor LGA1366 3.06GHZ Bloomfield 8MB LGA1366 4.8GT/S
LG CH10LS20 Bluray Reader & DVD Writer Combo Drive 10X BD-ROM 16X DVD-RW Lightscribe *IR-$10*
Corsair Cooling Air Series A70 HIGH-PERFORMANCE DUAL-FAN CPU Cooler LGA775 LGA1156 LGA1366 AM2 AM3
ASUS M4A89GTD PRO/USB3 AM3 DDR3 AMD 890GX ATX 2PCI-E16 PCI-E1 PCI-E4 2PCI VGA DVI Motherboard
XFX Radeon HD 5870 HD587XZNFC 850MHZ 1Gb GDDR5 2XDVI HDMI Display Port DIRECTX11 PCI-E Video Card
This is my first computer I plan on building and any input would be appreciated.
4 answers Last reply
More about help build
  1. Get rid of the green HD
    Need an Intel board not AMD...
  2. Thanks what kind of HD and motherboard would you recommend?
  3. Your mobo and CPU arent compatiable.
    wait a week or two and get this
    Core i5 2500k[CPU](Unless youre video editing you have no need for an i7)
    Asus P8p67 PRO (MOBO)
    12gb of ram is not needed for a gaming rig.
    get Hyper 212 + (CPU Cooler)
    ATi 6950 ( GPU)
    Samsung Spinpoint 1TB (HDD)
    Swap this with whatever is in your build with mine.
  4. purple goo guys build is good I would suggest the asus sabertooth p67 instead
New Build Systems
