Closed Solved
Printer Problem
Recently my Tech put my PC back to factory settings as he thought I had a virus.When I tried to install my printer again Windows 7 rejected the software disc,whats the problem?
7 answers Last reply Best Answer
More about printer problem
    And what do you mean by "rejected" ?
    Do other CD's read from the drive ?
  2. PS - your tech's an idiot for bringing you back to Factory settings because of a virus.
    need more details as to what you are seeing/doing (step by step)
    Yes,When I put the disc in up comes message,XThe version of this file is not compatible with version of windows you are running.Check your comp system info to see whether you need x86(32 bit) or x64 (64 bit)version of prog then contact software publisher.X I am running 64 bit version.
  4. Best answer
    go to the printer manufacturers website and download the software for Windows 7 64-bit.
    I tried this previously but it wouldn't let me,and after your answer tried again,IT WORKED,so im back printing again,many thanks for your help.
  6. Best answer selected by tamb00.
  7. This topic has been closed by Nikorr.
Virus Printers Factory Restore Windows 7
