Need advice on a mini-itx case.
Hello!
I'm building a general-purpose mini-itx PC, and I need some help selecting a case.
I'm currently looking at either the Lian Li PC-Q08 or the PC-Q11.
The PC-Q11 is smaller by about 4300 cubic cm. But I've been told that it may be difficult to cool.
Processor: Intel i5-760 quad core
Graphics: GTX 460
Motherboard: Zotac H55-ITX-C-E WiFi (side-note: I hear they're coming out with a H67 mini-itx board)
I have a magnetic hard drive and a modular PSU.
So... Which one do you suppose I should go with?
Thanks in advance!
3 answers Last reply
More about need advice mini case
  1. Li PC-Q08 would be my choice if going with a graphic card,... Comes with 1 120MM and 1 140MM, so cooling should be fine,...
    http://www.bit-tech.net/hardware/cases/2010/07/20/lian-li-pc-q08-review/1
  2. Thanks for the advice!
    But do you think the Q11 would be unmanageable?
    The thing is, I'm a student, and I have to move about 6 times each year, so that extra portability would be nice. Plus, a mini-tower form factor works better with the arrangement of my room. I have to place my PC under my desk, and the Q08's width may be a problem.
    Thanks again!
  3. ^ You could manage with the Q11, but am still skeptical about its cooling when compared to the Q08, also if going with Q11, then the GTX 460 with the blower-type cooler would be preferred,...
    This review gives a good idea of that case....
    http://www.bit-tech.net/hardware/cases/2010/10/08/lian-li-pc-q11-mini-itx-case-review/2
    The Q08 has better expandability and cooling, if you ask me that would be a better choice for you setup,...
New Build Cases Systems
