New gaming build 2000$+- with monitor Please comment on my picks
Approximate Purchase Date: This month
Budget Range: 2000$
System Usage from Most to Least Important: Gaming, medium photo editing and graphics.
Parts Not Required: keyboard, mouse, speakers
Preferred Website(s) for Parts: buying in Israel, checking parts in Newegg
Country of Origin: Israel
Parts Preferences: Intel with Radeon graphics, can accept nVidia if you think will be better
Overclocking: Probably yes
SLI or Crossfire: Yes in the future
Monitor Resolution: 1900x1200
COOLER MASTER HAF 932 Black RC-932-KWN3 Black Steel ATX Full Tower Computer Case with Side window
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119230
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Dell UltraSharp U2410 (464-7346) Black 24" 6ms HDMI Widescreen LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824260020
SAPPHIRE 100312SR Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102914
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
G.SKILL PI 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL6T-6GBPI
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231352
Intel Core i7-950 Bloomfield 3.06GHz LGA 1366 130W Quad-Core Processor BX80601950
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
OCZ Vertex 2 OCZSSD2-2VTXE120G 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227551
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
Noctua NH-D14 120mm & 140mm SSO CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Sandybridge will be available in Israel next month, I don't know if I should wait and if it will matter that much for gaming on 1900x1200 as GPU takes the most hits on such resolutions.
Thanks for your help
6 answers Last reply
More about gaming build 2000 monitor comment picks
  1. Looks like a nice rig, I'd not worry much over the possible 2-3 fps advantage that an overclocked SandyBridge might give in a few games....
    X58 rigs are still the flagship mainboards.
  2. Would my PSU be able to hold xfire 6950 in the future under full load?
    Unless you overclock the whole system (CPU, memory and videocards) to their absolute max, there will be no problems at all, and even if you did, it should still be enough, if just barely.
  4. Thanks for comments, anyone's else opinions please? :)
  5. Well I am looking for xfire in the near future and don't you think that 6950 in xfire will be enough for anything in the near 2-3 years? And cost like one 580?
Homebuilt Systems Product
