I bought a EVGA p67 SLI MOB. I have a corsair cooler m40. I want to add two fans to the radiator for a push/pull effect. My board has a bunch of 4 pin power ports on it for fans. I believe it has two for CPU. If someone could verify, I'm a little confused by the layout.
Also, if I want full power out of one of the ports for the pump I would switch it to manual in the bios and set it to 100, correct?
When I buy a 4 pin fan and plug it into the cpu part the Bios will control the speed based off of the temp.
If anyone could help me out and verify I could appreciate it.
Manual
http://www.evga.com/support/manuals/files/130-SB-E675.pdf
page 28
Thank you to who ever can help!
Manual
page 28
