Hi
I used to have a ton of informations on computers before (1 to 2 years from now) but I am not following the new products so excuse my question
1.I am about to build a new system (my priority is GAMING) so I was searching and I found that core i5 2500K is a good CPU for the money and powerful enough for hardcore gaming is that correct ?
2.what is the CHEAPEST and stil good Gigabyte MOBO that can support it fine(from the box) without any problems or needing updates ? and stil support at least 1333MHZ DDR3 memory ? I don't want any built in graphics ... I will get at least Geforece gtx570
3.Is gefore GTX 570 is a good graphic card or you have any other suggestions ?
4.Is 4GB 1333mhz ram is a good powerful ram for gaming or I should consider 1666mhz or more than 4GB ?
5.How much wattage and what type of power supply should I get for a resonable price ?
thanks alot
thanks alot
