Closed Solved
Corsair vengeance 16gb not running at 1600mhz
Hi i just built a new computer last week and every time i shut off my computer and turn it back on it keeps resetting my memory from 1600mhz to 1333mhz saying that the 1333mhz is more stable i checked all over the forums to correct this but could not find an answer to my problem. I'm pretty new to adjusting things in the bios so any help would be great. I just want my ram sticks to run at their default specs without having to change it back every time i restart my computer.
MB: ASUS Sabertooth 990FX AM3+ (bios version 0813)
http://www.newegg.com/Product/Prod [...] 6813131736
CPU: AMD FX-8120 3.1ghz
http://www.newegg.com/Product/Prod [...] 6819103961
RAM: CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (currently running at 1333mhz)
http://www.newegg.com/Product/Prod [...] 6820233235
PSU: Antec NEO ECO 620C 620W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS
http://www.newegg.com/Product/Prod [...] 6817371031
GPU: XFX Radeon 5850 BE
HD: seagate 700gb <-- don't know all the specs had it for over 3 years now
OS: Windows 7 professional sp1
3 answers Last reply Best Answer
More about corsair vengeance 16gb running 1600mhz
  1. If it is telling you that it is moving from 1600 to 1333 for stability reasons, there is probably not much you can do to convince it that 1600 is more stable than 1333.
    The difference is also probably pretty slight.
    I would just let it do like it wants to do.
  2. Best answer
    Those sticks will run at 1600MHz if the Voltage is set to 1.5V.
    If they are left to auto, the voltages drop to 1.45V and that send the stability@1600MHz for a toss.
    What you need to do is get into the BIOS , go to/find the RAM timing/settings section and change the Voltage to 1.5V.
    The newegg links you posted seem dead, all I could find there regarding the ram is either one of these two.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233143
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145347
    The second one is not listed in the QVL but the first one is.
    BIOS:
    Under the Heading AI Tweaker there is a Heading called DRAM Voltage. You will be able to change it from Auto to 1.5V if you choose the DOCP option in the AI Overclock Tuner, which is set to Auto by default.
  3. Best answer selected by wooshna.
Memory Computer Product
