Yes No
Ads
Wireless Network Problems
Forum Wireless Networking : Setup, Configuration & Security Wireless Network Problems
I tried to follow the various instructions on the web for Securing my DI-264 Network; but I think I messed up somehow !!! It is still not Secure and it wont "talk "to me anymore; I can't get it to accept a password even !!!
Reply to rmgard
reset the router and start over
Reply to Emerald
It sounds like a problem with your router. I thought a firmware upgrade would fix your problem, but it looks like you're already on the latest firmware.
Does your laptop have a 802.11g card in it? If so, double-check that the D-Link router is configured for ""g only"" and not ""mixed mode"". That will make better use of the available bandwidth. One other possibility might be to turn off security if you're using it. You could probably get by with MAC address filtering to keep people from free-loading on your internet connection.
Of course if all this fails I recommend you get a new router. Personally I despise the D-Link routers. I'd recommend a Linksys WRT54GL if you want something high quality at a decent price. You can pick one up for $40-$60.
Reply to lihuahellen
my guess..you tried changing the credentials of the network from a wireless computer and after you applied the settings you got the problem of 'not talking'...clear the preferred networks or previously saved networks list and try reconnecting to the w/l with the password that you set...but i'm just contemplating you did something similar...
Reply to optimusprime619
Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Wireless Network Problems
There are 2001 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help with wifi?
By Ubrales, 8 days ago:
Yes it will work fine! Earlier this week I installed two Linksys AE1000 wireless...
Best offers
Top experts
