Sign-in / Sign-up
Matshita DVD RAM UJ-141ES SATA Device problems
  • Drivers
  • DVD
  • Windows 7
Last response: in Windows 7
November 21, 2011 6:24:02 PM
After installing iTunes I could no longer find the D: drive or CD-ROM/DVD BlueRay drive
More about : matshita dvd ram 141es sata device problems
a b $ Windows 7
November 21, 2011 9:15:00 PM
Depending on what unit you have, some Pc's dont display your CD-Rom/DvD unless there is a disc in there, As for your D drive it's possible that an external device had the same driver letter and has unallocated that "D" to the drive.. Reboot/complete updates..
m
l
a b $ Windows 7
November 21, 2011 10:52:33 PM
Going by this thread http://www.tomshardware.com/forum/242550-32-matshita-85... , following procedure sounds to have worked for many people. You may want to try that.
Follow this procedure to resolve the error if the optical drive is missing from Computer in the Microsoft® Windows Vista™ operating system.
WARNING: There is a risk of data loss. This procedure involves editing the Registry. Using the Registry editor incorrectly can cause serious problems that may require the operating system to be reinstalled and can result in the potential loss of data.
NOTE: A backup of the registry can be created.
Click the Start button, and then in the search box, type regedit.
Press the Enter key.
NOTE: If prompted for an administrator password or a User Account Control prompt is displayed, type the appropriate password or click Continue.
In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
In the System folder, double-click the CurrentControlSet folder.
In the CurrentControlSet folder, double-click the Control folder.
In the Control folder, double-click the Class folder.
In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
In the right pane, click to select the UpperFilters registry value.
On the menu bar, click Edit.
In the Edit menu, click Delete.
In the Confirm Value Delete dialog box, click the Yes button.
In the right pane, click to select the LowerFilters registry value.
NOTE: Do not delete the UpperFiltersBak or LowerFiltersBak registry values.
Close the Registry Editor window.
Restart the computer.
m
l
a b $ Windows 7
November 21, 2011 10:53:37 PM
Please post results here so that others may benefit too - thank you!!!
m
l
a b $ Windows 7
November 22, 2011 12:03:29 AM
Ok... About all the nonsense you just slapped us with...
1. There talking about vista (Completely different Operating Systems)
2. The person with that issue has given the error code: "The driver may be corrupted or missing. (Code 39)".......... Our user has said nothing along the lines of any errors codes...
3. On the extreme off chance that the two operating systems had the same error coeds for that particular issue... there is still no telling that this fix would work for windows 7.. and the fix was due to a reg edit... and the issue was caused by a VISTA update....
4. Your link and this issue are completely different, sorry.
m
l
a b \ Driver
a c 262 $ Windows 7
November 22, 2011 12:31:43 AM
what you see under control panel peripheral
m
l
June 19, 2014 7:53:24 AM
Thanks for this, just came across this problem with win7, I had tried several basic solutions posted elsewhere with no luck. Your regedit solution fixed me right up, Thanks
m
l
