Closed Solved
MSI GTX 460 Cyclone 1GB clock speed halved issue
Hello everyone,
I have this issue I've been researching for the past couple of days, but I haven't found a concrete answer.
The GPU default speed is 725Mhz, I used MSI Afterburner to set the speed to 800Mhz with a default voltage. (800/1600/1800)
On idle, the clock speeds are halved when I view them in GPU-Z. When I load a game up a game, say Starcraft 2. The clocks run at full and then settle back down to half. Is this normal or is there a problem?
So far I've found out the following and I'm trying to determine what's true. Is there something I'm missing?
- The GPU automatically down clocks because it is idle and conserves power
- The GPU is flawed and I should RMA/get a new one
- The overclock isn't stable and it's down clocking for safety
- The voltage applied to the card isn't enough
- The power supply is not sufficient
Currently running:
E2160 stock
Corsair 2x2 GB XMS
Gigabyte GA-P35-DS3L
Corsair HX 520W
Many thanks in advance!
5 answers Last reply Best Answer
More about cyclone clock speed halved issue
  1. Best answer
    "- The GPU automatically down clocks because it is idle and conserves power"
    Bingo.
    And off-topic, get a new CPU, Starcrat 2 will poop on that one.
    Bingo.
    I noticed a steep drop in FPS last night in SC2, got down to 9 at one point. Will be popping in a Q6600 and oc to 3.0Ghz. Hopefully that helps.
    Thanks for the quick replies Benski and Dipankar2007i!
  3. Yup you can expect this from every new card now of days. Usually 3 or 4 profiles, only problem i have with it is that when i load up something like IE9 which kicks my card into profile 2 just above idle and then load a game if i didn't close IE9 it sometimes get stuck in profile 2, but hey few bucks a month on my power bill who's to complain.
  4. Best answer selected by ddhleigh.
  5. This topic has been closed by Mousemonkey
Graphics Cards GPUs Graphics MSI-Microstar
