Hello,
I am looking to upgrade from a old computer, and I have the following parts:
RAM: OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227365
PSU: Corsair 750w PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&cm_re=corsair_psu-_-17-139-006-_-Product
Case:Coolermaster ATCS 840
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119187
So I want to upgrade to a Sandy Bridges I5 2500k , whats a good mobo???
I was looking to save some money so does anyone have some suggestions on mobos????
I browsed around and saw alot of people recommend the asus pro but what about this board??
GIGABYTE GA-P67A-UD3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128460
Any reasons on if this board is good or not???
The asus is a little higher than I wanted so I'd like to hear about it. Thanks
