Brand new build using an Asus P8P67 Pro motherboard and I have a kit (2 sticks, 2G each, 4G total) of Patriot Pc3-12800 1600mhz memory (PGV34G1600ELK).
I installed the memory but I got a red light on the Memory OK led. So, I did some research and found this site:
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-boot-video-problems
So I pulled out one stick and viola, the computer boots fine on one stick. So that guide says that the next step is to "manually set the RAM speed, timings, and voltage to the manufacturers specs in the BIOS before attempting to boot with all sticks of RAM installed."
The problem is, I don't really understand what that means. I went into the BIOs and put it into ASUS Optimal mode. I then also went into the advanced settings and changed the memory voltage to 1.8, but then the computer wouldn't boot with even 1 stick. So, I changed it back and then figured that I should seek some expert guidance.
Can someone give me a little advice on what I should (and should not) be doing?
Thanks
Miles
Thanks
Miles
