Solved
HP 6619f - I would like to upgrade GPU - but Not sure if enough power?
I've got a family member with a Pre-built HP -that would like Dual Monitors added if possible.
Model HP A6629f
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01549568&tmp_track_link=ot_faqs/top_issues/en_us/c01549568/loc:4&lc=en&dlc=en&cc=us&lang=en&product=3809093#N74
Specs
CPU - Intel E2200 ( low power consumption )
MOBO #
Manufacturer: Asus
Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
Chipset:
Northbridge chipset: Intel G33 Express
Southbridge chipset: Intel ICH9R
GPU
Integrated graphics using Intel GMA 3100
*Integrated video is not available if a graphics card is installed
Also supports PCI Express x16 graphics cards*
Power supply - 250 W
When I use Newegg PSU calculator - and upgrade spec to a Geforce 2100, The Calculator shows 249 Watts.
Is this PSU too tight to upgrade Geforce 2100 Video card without causing problems in the computer. Also, not quite sure what happens when the Power Supply is being maxed out - as I've always built with headroom on the power side.
Could the power supply cause problems with other components - or - is it safe to just pop in a low end graphics card. The PC is only used for General web surfing ( somestreaming video content ) - Microsoft Office, etc.
I don't know how to get the Factory PSU out - it's built inside pretty good - so not quite sure upgrading the Power Supply is an option.
Is this upgrade doable - or not advisable?
Thanks
3 answers Last reply Best Answer
More about 6619f upgrade power
  1. Best answer
    If it is just for dual monitor support then GT210 HD4350 or HD5450 will all run on that PSU system draw will be under 200watts. A HD5570 would work as well if there is some casual gaming going on.
    Do not use newegg's calculator this one is better http://extreme.outervision.com/psucalculatorlite.jsp
  2. I've seen plenty of similar systems with 4650's, 4670's, and 9600GT's installed. You should have enough power available for any entry-level or mainstream card.
  3. Best answer selected by JessieJ.
Prebuilt Hewlett Packard Intel Systems
