Is my mobo, cpu and psu fried, connected wrong cable, help
Hi,
This is my first build, although I have done bits of building in college. I connected everything up and turned on the computer. After a few seconds there was a burning smell, and nothing displaying on the screen. I quickly plugged it out.
I know what I done wrong now, I had connected a 4-pin floppy power cable into a 3-pin fan connector on the mobo for the case fan. I thought the cable was for a 4-pin fan. The cable I connected has 2 black wires, a red wire and a yellow wire. I left the yellow wire unconnected. I believe this is what caused the burning. I now know that I need a molex to 3-pin adaptor to connect my case fan.
I wanted to see if the computer was ok after this happened so I took out the floppy cable from the mobo and just connected the case fan to the psu, with no connection to the mobo. I turned on the computer again, it will not boot, no beep signal, nothing on screen.
So my question is what components are fried? It seems that the mobo is dead. I tested the psu, and the -5v parameter does not seem to work, but I don't trust the PSU tester that i used as it is a cheap one. Could it have damaged any more of my components? e.g CPU, RAM, hard drive etc. What components do you think could be damaged?
I think my motherboard is dead and possibly the psu, and I will RMA these back to the retailer. But I dont know if my cpu is fried or not. Has anybody had experience of this happening before, and if so what components do you think are affected.
Grateful for any help or suggestions. Thanks!
Mobo: Asus P7H55-M
CPU: Core i3 540
HD: Samsung 1TB F3
Case: CIT Black Micro ATX 450W
RAM: ValueRam 4GB DDR3
2 answers Last reply
More about mobo fried connected wrong cable help
  1. What kind of PSU?
    Work systematically through our standard checklist and troubleshooting thread:
    http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
    I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
    If not, continue.
    I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
    Breadboard - that will help isolate any kind of case problem you might have.
    http://www.tomshardware.com/forum/262730-31-breadboarding
    Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
    Make sure you plug the CPU power cable in. The system will not boot without it.
    I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
    You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
    If no beeps:
    Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
    At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
    The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
    You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
    http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
    A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
    This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
    If the system beeps:
    If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
    Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
    Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
    At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
    Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
New Build Fan Cable Systems
