Speed of bi-directional parallel port vs usb port
Last response: in Components
Hello,
Our machine shop is buying a plasma cutting table, and the salesman says any reasonable xp machine will do, laptop or desktop, as long as it has a parallel port.
New laptops generally don't have parallel ports, so I was hoping to simply get a parallel-to-usb adapter for use with a laptop.
The supplier tech person says 'NO', because they need the speed of a bi-directional parallel port; and that my solution would be too slow, with the usb port.
This makes me ask: What is the relative speed of usb 2.0 versus a parallel port?
Thank you.
The speed of a USB port is much faster than a parallel port the typical maximum speed for a parallel port is 16 Mbps and a USB port is 480 Mbps. The speed of the parallel port is much slower because of handshaking and bit skewing.
However this does not mean that a USB to parallel converter will work, whether it does or not depends on how the programs software has been written.
Ask the community
