Hello all,
Approximate Purchase Date: sometime soon. I might wait and see what deals pop up
Budget Range: Roughly $1200
System Usage from Most to Least Important: Video Production, Gaming
Preferred Website(s) for Parts: Amazon >>>> Newegg
Country of Origin: US
Parts Preferences: Intel and Nvidia, and i like the case i chose even though its a tad expensive
Overclocking: Yes
SLI or Crossfire: Not planning on it
Monitor Resolution: 2048x115
Ive built a system before but ill admit im a bit rusty in the area of actually choosing components. Im pretty sure all these components work for my system and what i plan to use it for, but i want to be absolutely certain. (yes i know there is no cd drive listed). Just let me know what you think.
any constructive help is appreciated.
Chassis:
Thermaltake Element V Black - $150
http://www.thermaltakeusa.com/Product.aspx?S=1321&ID=1959
Motherboard:
ASUS P6X58D-E - $240
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
GPU:
GTX 460 - $190
http://www.amazon.com/dp/B003XU78OA/ref=asc_df_B003XU78OA1388789?smid=ATVPDKIKX0DER&tag=pg-469-34-20&linkCode=asn&creative=395093&creativeASIN=B003XU78OA
CPU:
Intel i7 950 3.06 GHz - $300 (I have little idea what Sandy Bridge is, but if thats better than this selection please let me know)
http://www.amazon.com/Intel-3-06GHz-LGA1366-Desktop-Processor/dp/B002A6G3V2/ref=pd_bxgy_e_text_b
Sandy Bridge:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&cm_re=sandy_bridge-_-19-115-070-_-Product
Power Supply:
Corsair 650 Watt - $90
http://www.amazon.com/Corsair-CMPSU-650TX-650-Watt-Certified-Supply/dp/B000X24ISU/ref=pd_bxgy_e_img_b
Memory:
Corsair XMS3 6GB - $75
http://www.amazon.com/Corsair-PC3-10666-1333MHz-Channel-CMX6GX3M3A1333C9/dp/B002LYTF2W/ref=sr_1_12?s=electronics&ie=UTF8&qid=1294803654&sr=1-12
SSD:
Kingston 128GB - $200 (probably not getting a 128 but a 64)
http://www.amazon.com/Kingston-SSDNow-Solid-SNV425-S2-128GB/dp/B00378KHV4/ref=sr_1_12?ie=UTF8&qid=1294804314&sr=8-12
Total - $1245
Main goal of this computer: Gaming, not especially bent on playing at ridiculously resolutions but i want the power there. There will be a lot of video production on this computer as well.
Thanks!
Overclocking: Yes
Chassis:
Motherboard:
GPU:
GTX 460 - $190
CPU:
Sandy Bridge:
Power Supply:
Memory:
SSD:
Total - $1245
Thanks!
