Sign-in / Sign-up
Solved
Im willing to buy this ..?(need ur help)
  • Components
  • Product
Last response: in Components
April 7, 2011 8:52:30 AM
Hello guys , this is my first post in tomshardware :D
Im going to buy this PC:
Intel i5 2500 3.3GHZ
Gigabyte GA-A67A-UD3-B3 socket 1155
Radeon 6850 HD ( which brand shall i buy Msi OC , Sapphire toxic , HIS iceQ x turbo)
NZXT lexa s
Adata premier series 1x4GB DDR3 1333 CL9
W.D. Caviar Black 1TB
Antec EarthWatts EA 500W PSU
Sony DRU-870S 24x DVD-RW drive
Any replacements suggestions would be thankful , Do i need more WATTS ? , Is the 6850 a Decent VGA? or the GTX 460 1gb is better?
Anything u think i can change it plz tell ( but stick to the same budget range ;)  ) , Asus's Mobo's or gigabyte?
PS: im building this for gaming and some graphics programs ( photoshop , autocad , 3D max)
thanks
More about : buy
Best solution
April 7, 2011 9:56:27 AM
I5 2500K
Asus P8P67
2x2GB ram instead of a single 4GB, photoshop, autocad and 3dmax would all benefit from 2x4GB, brand personal preference.
HD6850 is a good card manufacturer is a personal preference between those three I would select based on price, maybe throw XFX and Asus into the selection.
EA500D is an good PSU and plenty for that setup.
April 7, 2011 10:04:56 AM
My two favorite video card brands are eVGA for nVidia cards and XFX for ATI/AMD cards.
m
l
April 7, 2011 10:06:26 AM
the 2500K is not available here in egypt , and i think the K version is only for OC , i dont think im going to OC , about the ram im buying 4GB now and will buy 2nd one later , Asus 6850 not available but XFX is and i was thinking to buy the iceQ x turbo as it says that it has good cooling
and thanks for quick responding ;)
m
l
April 7, 2011 10:11:14 AM
@Jsc : only 1 shop sells the XFX 6850 :D  and its not the shop im buying the PC at , plus the only version available isnt OC'ed , thx for ur reply ;)
m
l
April 7, 2011 4:03:13 PM
I have used three different HIS cards with the IceQ coolers, and all were quiet, and ran cool.
m
l
April 7, 2011 4:15:20 PM
jtt283 thanks man , i think im going for the HIS card then :)
m
l
April 8, 2011 9:35:06 PM
why does the system requirement of the VGA is 500 WATT or more :/
m
l
April 15, 2011 3:07:12 PM
Best answer selected by Chester cheta.
m
l
