Solved
Only 1 of 3 case fans running on rosewill challenger
Hi,
I have a rosewill challenger case, a seasonic 650w x-series psu, and an Asus P8P67-M Pro motherboard. Not overclocking right now and CPU temperature is showing at 25 degrees Celsius. My concern is that only 1 of the three case fans is running -- the rear one which is connected to the motherboard via a 3 pin connector to the PWR_FAN.
The other fans are on the top and the front and neither are running. These have molex connectors and I daisy-chained them together and then used a supplied y-adapter (1 molex to (2) 4-pin connectors) to connect the daisy-chained fans to the motherboard to CHA_FAN1 and CHA_FAN2. But neither fan runs. Do they not run because they're not cabled properly or because the temperature in the case is low enough where they don't need to run?
Should I not use the y-adapter, not daisy-chain the fans together, and simply purchase and use molex to 4-pin (or 3-pin) adapters? If the latter, where to buy these cheap?
Thanks in advance for any help you can provide.
3 answers Last reply Best Answer
More about only case fans running rosewill challenger
  1. Best answer
    25 degrees is a nice low case temp. That is probably why the motherboard CHA_FAN 1& 2 don't turn ON. I like to see the front fan, top, and the rear fan run at full speed and I suggest that you connect these fans directly to the PSU using Molex connectors daisy-chained as you suggested. Leave out the Y-adapter because I read elsewhere about some product issues on this (may be ok now).
    http://www.newegg.com/Product/Product.aspx?Item=N82E16812201009&cm_re=fan_cables-_-12-201-009-_-Product
    Try your local computer store too, for the Molex fan cables (daisy-chaining type).
  2. Best answer selected by Alduron.
  3. Thank you!
Power Supplies Rosewill Cases Motherboards Components Product
