Dental Ring Light
Forum Digital Camera : Digital Camera General - Dental Ring Light
Archived from groups: rec.photo.digital (More info?)
I'm having trouble finding quality high intensity LEDs.
My first batch projects a yellow ring with green tint in the middle.
Is there such a thing as a true white high intensity LED ?
Gene http://www.photoprojects.net/
Sponsored Links
On Wed, 26 Jan 2005 19:34:03 -0600, "Gene F. Rhodes" <"gfrhodes"@ cox.net>
Gene,
Ya might do well you ask the guys in this newsgroup:
alt.binaries.schematics.electronic
They do all kinds of neat stuff with LEDs.
Reply to Anonymous
Good high intensity LEDs are luxeon led - I have a 3W Luxeon flashlight. It
is super bright and white, but more like fluorescent white tint (quite a bit
of blue in it).
"Gene F. Rhodes" <"gfrhodes"@ cox.net> wrote in message
news:eyXJd.4688$A_.3528@okepread03...
Reply to snowman
Depends what you mean by "true white". If you're asking if a LED can
emit white light the answer is yes... sort of...
White LED's are actually have three separate LED's (red, green and
blue) inside the one LED package. The three LED's produce white by
mixing the output of the three separate LED's in the correct
proportions to produce white.
Reply to Anonymous
I believe there are LEDs where the three colors can be controlled
independently, which would allow him to achieve whichever color temperature
he wanted. : )
steve
Reply to Anonymous
"Gene F. Rhodes" <"gfrhodes"@ cox.net> writes:
Well presumably there is, since there are LED ring lights for sale, such as:
http://www.bhphotovideo.com/bnh/co [...] 937&is=REG
Michael Meissner
email: mrmnews@the-meissners.org
http://www.the-meissners.org
Reply to Anonymous
NOsecSPAM@nbnet.nb.ca writes:
Actually, most "white" LEDs are actually blue-emitting LEDs with a
phosphor coating. The phosphor absorbs some of the blue and emits
yellow-green instead. So you get whitish light, but the colour often
changes with angle off axis, and colour rendition isn't that good.
A real 3-chip LED would be better, but more expensive.
Dave
Reply to Anonymous
Very true ... the "white" is actually a relatively strong bluish color. I
would ask to see a spectral plot of the LED's output before trying to use
it for photography.
First:
I have been somewhat disappointed with the so-called "white LEDs" so far
.... even in flashlight-type applications.
Second:
I would love to try a three-LED light source ... one with Red-Blue-Green
LEDs. Who makes one?
"Dave Martindale" <davem@cs.ubc.ca> wrote in message
news:cti53b$jpo$2@mughi.cs.ubc.ca...
> Dave
Reply to Anonymous
> First:
> Second:
A quick perusal of Digikey's catalog turned up options from Lumex and
Panasonic, ranging from $2.30 to over $11.00 each in low quantities. I only
skimmed through very quickly, I imagine that there will be options from
other manufacturers as well.
steve
Reply to Anonymous
http://www.superbrightleds.com/
have good quality LEDs compared to some others.
Gene http://www.photoprojects.net/dental.html
Steve Wolfe wrote:
> > First:
> > Second:
> steve
Reply to Anonymous
Tom's Hardware > Forum > Digital Camera > Digital Camera General > Dental Ring Light
There are 1190 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
