Which power supply should i buy?
Im pretty sure my power suppply has gone bad. My hard drive keeps spinning down then the computer freezes. Cant even get windows to fully load.
Im planning on upgrading my computer to a i7 2600k build within a year and want a power supply that can carry over. I will still use my GTX 460 in the new build and may buy a second for SLI. I wont be buying any additional hard drives though i may replace my main drive with a WD Black.
Current Build
CPU
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 65W Dual-Core Processor BX80557E6600
ZEROtherm CF900 92mm CPU Cooler
Mother Board
Asus P5B Deluxe LGA 775 Intel P965 Express ATX Intel Motherboard
RAM
OCZ Platinum Revision 2 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2P800R22GK
Graphics Card
EVGA 01G-P3-1371-AR GeForce GTX 460 (Fermi) FPB EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Case
APEVIA X-Infinity ATXB6KLW-BK/420 Black Steel ATX Mid Tower Computer Case
Power Supply
Antec NeoPower 550 550W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply
Hard Drives
1 x Western Digital Caviar Blue WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
2 x Western Digital Caviar Green WD10EADS 1TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Current Build
CPU
Mother Board
RAM
Graphics Card
Case
Power Supply
Hard Drives
