battery question
Forum Laptops & Notebooks : General Laptops & Notebooks - battery question
Archived from groups: comp.sys.laptops (More info?)
I have a Pavilion zd8080. I run 95% of the time from the powercord. Should I
keep the battery in at all times? Or just keep it out until I anticipate
using the battery? I never deplete all of it's charge. So is it giving
itself a charge everytime I plug the machine in?
Thanks
Jeff
Sponsored Links
"solrpwr" <solrpwr@yahoo.com> wrote in message
news:42248cda$1@news.qgraph.com...
I
| Thanks
| Jeff
Decent read on the battery question @
http://www.batteryuniversity.com/parttwo-34.htm
D
I'm not an MVP a VIP nor do I have ESP.
I was just trying to help.
Please use your own best judgment before implementing any suggestions or
advice herein.
No warranty is expressed or implied.
Your mileage may vary.
See store for details. :)
Remove shoes to E-mail.
Reply to Anonymous
The consensus is that you should remove that battery and get an
inexpensive $30 (or less) UPS (typically, an APC 350VA model).
In very many cases, a combination of heat and overcharging (which
produces heat) will destroy the battery over a period of 9 to 24 months
if you leave it in while running for long periods of time on AC.
> Thanks
> Jeff
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > battery question
There are 563 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
