Building new system 3D
Hi Frinds,
Building new System For 3D Gaming, Movie Experience and for long lasting Future purpose atleast 4-5yrs
So far calculated Requirements according to my Budget that are-
AMD PHENOM II X6 1055T
4GB HYPERX KINGSTON KIT
NZXT PHANTOM CABINET or AERO Cool Predictor
CORSAIR H50
2X1TB WD GREEN
Blu Ray LG DVD RW
NOW I am stuck with Graphic card solution
As I support and fan of ATI its hard to go for Nvidia only for 3D, but while searching I found this-http://www.amd.com/us/products/technologies/amd-hd3d/Pages/supported-hardware.aspx
but not sure How many tried this and 3D solution really works for them
As if that case does it really saves money and give performance compared Nvidia? obviously Graphic card choice will matter bt lets consider graphic card from both companies of nearly equivalent capabilities then which one?? But is it worth to Go for this ATi solution, is it tested,proven,favourable by techies or Nvidia still serves best when comes to 3D in Desktops?
If opt for ATI which one to go with and if no choice then Help me chosing bet. Msi N460gtx cyclone and Zotac 470gtx
Choice for motherboard depends upon graphic card so either crosfire or sli
Then comes PSU, system will run 24 x 7 at least thrice a week so corsair HX series should be good or seasonic s12D is good choice?
About Monitor Dell Alienware 3D is in my sight,ny recommendation?
Kindly Give Helpful advice,suggestions
Thnx in advance,
4 answers Last reply
More about building system
  1. currently, for gaming anyway, 6 core is actually at a disadvantage due to small anount of resource/OS overhead servicng a couple of unused cores...
    Save yourself $80-$100, drop to a quad core, and put the savings into a 6950 or GTX570
  2. (Incidentally, unless you intend to play today's COD/Black Ops for 5 years, generally that is a lifetime in the computer industry.....; if it still plays new titles for 2 or 3 years, you are doing well)
  3. mdd1963,
    Thank you for advice.
    So which Processor I should look for Phenom II x4 965? or any different Processor u will recommend?
    And as I am looking for 3D solution kindly have words on doubts/questions I posted regarding GPUs-
    Would be pleased to hear advice on Monitor, PSU and other config I mentioned
    Thnx.
  4. After reading lots of reviews I am still not able to finalise GPU, can u help me folks-
    Pupose as I say earlier- Overclock, 3D & Gaming
    Palit NVIDIA Geforce GTX 460 1GB GDDR5 Sonic Platinum- 318$
    Palit NVIDIA Geforce GTX 460 2GB GDDR5 Sonic- 312$
    MSI 470 TWIN FROZER- 318.50$
    MSI N460GTX HAWK-Talon Attack Version- 301.66$
    MSI N465GTX Twin Frozr II- 294$
    ZOTAC GeForce GTX 460 2GB Graphics Card- 318$
    Zotac Geforce GTX 460 Amp Graphics Card- 274$
Prebuilt Graphics Cards 3D Systems
