First start off with the computer spec's
CPU - AMD Athlon x2 5400
MB - Comes up as NF-MCP68 which I found as a MB made by Nvidia
RAM - 4GB DDR2 @ 1.692Mhz
Video - nVidia 9500 GT 512MB
HDD - Western Digital 350GB
PSU - RaidMax 450W
Sound - RealTek HD (onboard)
My problem is this. While playing any game I encounter this problem within 10-15 minutes of play. The sound will seem to skip or stutter sounding like a CD skipping. Then it will correct itself. The problem gets continually worse and other symptoms include looping audio but a stuck video and always end up in a total system lock. I get no error or BSOD. I have run multiple types of burn software to include Hot CPU Tester Pro, Memtest, BurnIn, ORTHOS, IntelBurnTest, rthdrbl, and Prime95. I used SpeedFan and RivaTuner to monitor temps during the Burn process. I ran these tests for multiple hours (obviously not at the same time) and cannot replicate the error. It will only occur while a game is actually running. I have used a power supply calculator to try to rule out the power supply and I can also monitor the voltages in real time using speedfan. I did other research using my system spec's and I got a few hits with problems regarding my sound card but I couldn't really find one that gave a solution. The only other thing that I am going to try tonight is running the game in a windowed mode with SpeedFan to see if the point that it locks up is consistent with a temperature or load. Any thoughts or opinions are appreciated. Thanks
Robert
PSU - RaidMax 450W
Robert
