Closed Solved
EVGA GTX 460 Installation problem
Hi,
Try to install GTX 460 on my Gigabyte PCI-e.
260.99 driver can't install.
It said "driver can't find compatible hardware".
Please help me how to.
Thanks,
9 answers Last reply Best Answer
More about evga installation problem
  1. Have you tried older drivers?
  2. Best answer
    Is your GTX 460 properly plugged in, like the two 6-pin power plugs ?
    Go to device manager and tell us what it says under display adapters.
  3. As suggested, make sure its properly connected with the two 6 pins..
  4. Thanks Guys!
    I didn't plug in 2nd 6 pin power connector. It works fine now.
  5. = P
    had a feeling that's what it was.
    How about you give me one of those 'best answer' things, I never get any! LOL
  6. Yeah send a best answer his way! lol
  7. Best answer selected by firework.
  8. Haha thanks man! And glad to help of course, though I'm sure you would have figured it out eventually.
  9. This topic has been closed by Mousemonkey
Graphics Cards Gtx EVGA Compatibility Gigabyte PCI Express Graphics
