First build ever, do I need anything else? will it work?
I am nervous, are there any guides that can walk me thru on how to build that are free and online.?
Is ram compatible?
Will case work with the fans that will be included? do I have to order more fans? if so can you point to a link?
do i really need cpu cooler? Do i need the paste? (what the heck is the thermal compoundI
I have monitor, keyboard, dvd drive, windows. thanks in advance
Qty. Product Description Savings Total Price
SAMSUNG 22X DVD±R DVD Burner Black EIDE/ATAPI Model SH-S222A - OEM
Item #: N82E16827151175
Return Policy: Standard Return Policy
$17.99
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152185
$69.99
EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ...
Item #: N82E16814130595
Return Policy: VGA Replacement Only Return Policy
$369.99
NVIDIA Free Just Cause 2 + Mafia II Coupon
Item #: N82E16800999242
Return Policy: Limited Replacement Only Return Policy
-$59.99 Saving
$59.99
$0.00
Tuniq TX-2 Cooling Thermal Compound
Item #: N82E16835154003
$6.99
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Item #: N82E16820231314
Return Policy: Memory Standard Return Policy
$109.99
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
Item #: N82E16811119225
COOLER MASTER Silent Pro RSA00-AMBAJ3-US 1000W ATX12V v2.3 / EPS12V v2.92 SLI Ready 80 PLUS BRONZE Certified Modular Active ...
Item #: N82E16817171049
-$20.00 Instant
-$40.00 Combo
$389.98
$329.98
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
Item #: N82E16819115072
Return Policy: CPU Replacement Only Return Policy
ASUS P8P67 PRO LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131682
Intel Sid Meier's Civilization V Free Game for CPU promo Free with purchase!
Item #: N82E16800995100
-$5.00 Instant
-$59.99 Combo
$454.97
$389.98
Subtotal: $1,294.91
Ca
Grand Total: $1,296.58
7 answers Last reply
More about first build ever else work
  1. will this memory work? seems cheaper
    G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
  2. off topic
    why do promo codes not work with newegg if ordering multiple items? better to order promo items separately rather then bulk it up?
  3. what u think?
  4. I see no one replied your post yet. I'll see what I can do then...
    The parts seems fine and should work.
    The cheaper RAM can work if you decided to get it. It's just (insignificantly) slower than your first choice.
    I don't know about Newegg's promos. Sorry...
    You'll need a better CPU cooler if you plan on overclocking your CPU. But for standard use, the default one along with the CPU is good enough.
    Thermal compound is another name for thermal paste. And yes, you definitely need it to distribute the heat to the CPU cooler.
    Anymore questions?
  5. thanks damasvara,
    this is the perferred one by you right?
    "G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
    whats ur take on the cpu cooler i listed?
  6. You have a EIDE CD/DVD drive on there. You want a SATA...not an EIDE.
  7. I didn't see any CPU cooler, just thermal compound.
New Build Policy Systems
