Motherboard help?
December 14, 2011 3:04:10 PM
I am wondering if upgrading to this new mother board and (maybe) getting new ram and processor and psu that my comp will run swtor a lot better here is the link to the mother board tell me what you think
And here is the specs for my comp maybe if it's possible to Frankenstein some parts?
CPU: intel pentium D 946 dual
core voltage 1.247 V
Intel(R) Pentium(R) D CPU 3.40GHz
core speed: 2400.1 MHz
multiplier x12.0
bus speed 200.0 MHz
Rated FBS 800 MHz
MainBoard: model : OEMD975XLAG1 AAD50908-200
chipset: intel i975x
memory: dual channel 4x 2gb memory stick total 8gb
graphics card (right now) : Nvidea GeForce 8400gs 1024 mb
clock:
core 135 MHz
shader 1402 MHz
memory 333 MHz
PSU model DPS-400RB A
it says on lable PSU has 400w max setting.
More about : motherboard
December 14, 2011 3:42:27 PM
If you decide to get that motherboard you'll have to get a new cpu at least, your current cpu isn't supported on the new board. You can look at the list of supported cpus here:
http://www.asrock.com/mb/cpu.asp?Model=Z68%20Extreme3%2...
Guessing your memory is DDR2, you'd be upgrading that as well.
The PSU might be useable depending on the graphics card you use. For an oem unit its actually half-way decent.
m
l
December 14, 2011 3:47:15 PM
okay yay i did want to get a new CPU to not the craziest one in the game but a pretty darn good one. so i get this motherboard a new CPU, and new sticks of memory could i keep my same graphics card and PSU you say then?
m
l
